adam-mcintosh avatar image
adam-mcintosh asked
Orion Smart input voltage stuck at 11.9V
My Orion Smart states 11.9V all,of the time regardless whether the van is running, lights on etc.
status is always Off and
charge is disabled due to: input voltage lock out, engine shutdown detected.
does anyone know why the input voltage never changes even when driving etc. ?
VW transporter T6.1
Thanks
orion-tr smart
marc-heide avatar image
marc-heide answered ·
What do you measure on the input? Maybe alternator fuse blown?
It wont start charging because minimal is set to 12,4.
1. Or the voltage is realy 11.9 volt.
2. Or the orion would be defective.
But i would say option 1.
Normally the starter battery is charged with a charging voltage of approximately 14.4 volts. In Euro 5/6 cars, however, the charging voltage can drop to as much as 11.5 volts due to the above mechanism.
I always make sure to connect the D+ signal to the orion to force charging with euro 5/6 otherwise you get these kind of issues
With kind regards,
Marc
MarcES
adam-mcintosh answered ·
Thanks Marc,
On the Victron Connect app the input voltage is ALWAYS 11.9 regardless of driving.
I changed the lockout voltage down to 11.5 and nothing happens at all - it doesn't change anything.
Personally I think this unit is faulty - it used to work fine and it stopped.
Thanks,
marc-heide avatar image marc-heide commented ·
To maken sure i would measure the input. Than you know for sure.
regman54 avatar image
regman54 answered ·
Perhaps the vehicle's alternator is faulty. To rule that out, with the engine running, use a voltmeter to measure the voltage at the starting battery terminals. As mentioned it should be around 14.4 volts.
