When switched on led flashes red and then extinguishes. It is located in a motor home and has possible been exposed to ambient temp in excess of 40 degrees. All connections are tight. Any insight would be appreciated.
Hi, its months later now, so I’m sure you sorted it: I recommend to contact the dealer / distributor.
8 People are following this question.
