williams avatar image
williams asked
How to wire a 48V 102kw battery bank
I have a doubt, so in Victron they say I can build a 102kw 48V battery bank and that the maximum batteries in a system is of 20. I have done the math but is not possible for me to get the 102kw 48v battery bank with only 20 batteries and 5 strings parellelled limitation.
Maximum i can get with these limitations is 48V and 25600WH battery bank as per below
Am I doing something wrong? Could someone explain me how to build it?
Thanks
48v battery
Alexandra avatar image
Alexandra answered ·
@Williams
The limit is 20.
You have 10. So you are halfway there.
Add a second bank of parrallel pairs.
Use the example of image xxx70555 but with 25v batteries and the output being 48v.
X5
williams avatar image williams commented ·
Adding another row will get me to 51200 W/h. Still not reaching the 102kW for 48V as stated by Victron. Unless 51200 Wh is the max capacity for 48V bank?
Alexandra avatar image Alexandra ♦ williams commented ·
20 x 5120wh = 102 400 or 102kWh
I think that might be where the figure come in from.
williams avatar image williams Alexandra ♦ commented ·
Oh, I see. So, will end up as below correct?
prein avatar image
prein answered ·
In your picture, you create a 48V 51200Wh battery, not 25600.
2x 25,6V200Ah = 51.2V200Ah => 51,2*200=10240Wh = 10kWh
Oh, I see. So should be as below correct?
