Mark Anderson avatar image
Mark Anderson asked
Failing to get GPS Data via Modbus
HI All
I'm connecting my CerboGX to a home automation system (Home Assistant) via Modbus. I can get a lot of the dat but the GPS is not working.
My config YAML says this:
- name: "GPS Latitude"
data_type: int32
unit_of_measurement: "deg"
slave: 100
address: 2800
- name: "GPS Longitude"
data_type: int32
slave: 100
address: 2802
The sensor shows up buy with unavailable. The Cerbo GX shows this:
ERROR "Error processing function code 3, unit id 100,
start address 2802, quantity 1, src 192.168.50.171: Error
finding service with device type gps at device instance 0"
I don't see a unit ID for the GPS service anywhere, so I'm using 100
I see this in Home Assistant but status is unavailable
'sensor.gps_latitude'
'sensor.gps_longitude'
Any ideas?
Thanks
Mark
Modbus TCP
elvis avatar image elvis commented ·
I dont thinks it going to be ID 100.
Venus has to see your GPS and then you can go into the services modbus and get the right id.
Did you plug a GPS into the Cerbo? NMEA? USB?
xsilvergs avatar image
xsilvergs answered ·
@Mark Anderson
If i look under Device List > Settings > GPS > NMEA blah > Device at the bottom I see VRM instance, in my case it's 1.
This is using a Raspberry Pi and a USB GPS.
And from my Node-Red
