Fonnie avatar image
230V without neutral in Belgium
In Belgium we still have an electrical grid monophase (only 2 cables coming in) without neutral. I think Norway uses this system too.
It is originating from 3 phase 3 x 230V Delta configuration, from which L1 and L2 are coming to the my meterbox. I imagine my neighbours will be on L2-L3 and L1-L3 to divide the grid load.
there is NO neutral wire.
Which Victron system could be used to provide ESS functionallity? I already have a grid-tied solarinstallation, and would like to expand with ESS capabilities.
all help is greatly appriciated
best regards
Stefaan De Ridder
ESSHelp
Ahoi there,
Here i use a quattro 48/8000 on one fase ( L1-L2 ) , i have L1-L2-L3 without N ( 3x230 like we call it here in belgium)
I dont know how it can work with 3 quattros, i only have one on my koi pond and that is only using "1 line of the 3 lines".
To make it short..the systems runs good here..
Grtz kristof
Edit,
you can pm me in dutch if you want, i have quattro, grid inverters and grid inverter on output, dc mppts,.. maybe if not far from me..you can have a look here how its done
how did you connect the Quattro, if it switches, does it not pull the Line 1 or 2 to the ground? did you remove or bypass the GND relay.
i'm interested to pay a visit, if not too far away, I'm living in Tildonk, near Haacht and Leuven
Best regards
Stefaan
Fonnie avatar image
@Kristof: is your Quattro a recent version? and what kind of anti-island are you using. do you have a schematic of your system (wiring diagram) en waar woon je? je mag me PM sturen op stefaanderidder@telenet.be
@Wkirby: do you have an internal circuit diagram that clarifies the wiring of the relays for a Quattro and/or a Multiplus
best regards
Stefaan
2 comments Share
Yes, there are relay diagrams in the Appendix section of the manuals, which are available for all on www.victronenergy.com
Here is an example for the Quattro:
https://www.victronenergy.com/upload/documents/Manual-Quattro-3k-50-50A-230V-(firmware-xxxx4xx)-EN-NL-FR-DE-ES-SE.pdf
thanks, of course, Read the F.. Manual, did not check the annexes.
best regards
Stefaan
NigelFXS avatar image
Hi Stefaan
This type of grid connection would be very unusual - since the voltage between phases would then be 320 Vac.
I think you will be able to verify your grid supply configuration by measuring the AC voltage between the two incoming grid connections (it will be either 230Vac or 320Vac) as well as each line and local ground.
6 comments Share
These kind of supplies are actually 230V Line to Line. I don't know if it is a Delta or 127V Wye configuration, it depends upon the region.
It could also be a corner phase delta configuration where L1 is referenced to ground. Customers on L1-L2 or L1-L3 have a ground reference. The third customer who gets L2-L3 does not have a ground reference.
Thank goodness that there are less and less of these systems now.
Sorry, this does not answer the original question to which I don't know the answer, I'm not sure if the community is the right place to offer such advice.
The GND relay can be (must be) disabled if this sort of information is useful to your local electrician.
230V without Neutral is still common in Belgium. 230V between L1 and L2, 115V between Line and Ground. Is disabling the GND relay an easy task?
best regards
Stefaan
You can disable the ground relay in VE.Configure.
I should add that despite disabling the ground relay, ESS still won't work because a grid test will fail and the Multi / Quattro will not connect to mains.
Wkirby, thats wierd
Here i disabled the grond relay and i can feedin to grid..everything is working ( i tested even with the relay enabled and still working)
Not that it mathers ,but i have an anti island infront of everything.
Edit :
You state" I should add that despite disabling the ground relay, ESS still won't work because a grid test will fail and the Multi / Quattro will not connect to mains."
Why is that?
The test would fail to detect a neutral-earth bond upstream.
I don't think the older MultiPlus / Quattro's perform this test though, so maybe that's why some people are demonstrating it working.
