paulsch avatar image
paulsch asked
How to instal the usb wifi adapter for venus
The raspberry pi 3b I used to install venus, I used a metal case for the pi so the internal wifi dasnot work well. The wifi+bluetooth adapter 150 mbps RTL8723BU I have connected to the pi and disable the internal wifi and bluetooth. The command dmesg I used and see a error usb failed to load firmware. New firmware I try to install but it dasnot work.
root@raspberrypi2:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.110-rpi-venus-4 (oe-user@oe-host) (arm-ve-linu x-gnueabi-gcc (GCC) 9.5.0, GNU ld (GNU Binutils) 2.34.0.20200910) #1 SMP Tue Dec 5 23:19:16 UTC 2023
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] random: fast init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 M iB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id share d-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] DMA zone: 2133 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s51916 r8192 d21812 u81920
[ 0.000000] pcpu-alloc: s51916 r8192 d21812 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835 .enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_f b.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x 40000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 root=/dev/mmcblk0p3 rootwa it
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, li near)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 877720K/970752K available (10240K kernel code, 1333K rwda ta, 3100K rodata, 1024K init, 885K bss, 27496K reserved, 65536K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 33798 entries in 100 pages
[ 0.000000] ftrace: allocated 100 pages with 3 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jif fies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3b4/0x588 wit h crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980 46511078ns
[ 0.000024] Switching to timer-based delay loop, resolution 52ns
[ 0.000325] Console: colour dummy device 80x30
[ 0.000391] Calibrating delay loop (skipped), value calculated using timer fr equency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000425] pid_max: default: 32768 minimum: 301
[ 0.000631] LSM: Security Framework initializing
[ 0.000872] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linea r)
[ 0.000900] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002292] cgroup: Disabling memory control group subsystem
[ 0.002562] CPU: Testing write buffer coherency: ok
[ 0.003048] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004292] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004482] rcu: Hierarchical SRCU implementation.
[ 0.005607] smp: Bringing up secondary CPUs ...
[ 0.006755] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008028] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009255] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009421] smp: Brought up 1 node, 4 CPUs
[ 0.009463] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.009480] CPU: All CPU(s) started in HYP mode.
[ 0.009496] CPU: Virtualization extensions available.
[ 0.010573] devtmpfs: initialized
[ 0.028452] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.028710] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 19112604462750000 ns
[ 0.028746] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.031777] pinctrl core: initialized pinctrl subsystem
[ 0.032958] NET: Registered protocol family 16
[ 0.036958] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.042656] audit: initializing netlink subsys (disabled)
[ 0.042966] audit: type=2000 audit(0.040:1): state=initialized audit_enabled= 0 res=1
[ 0.043535] thermal_sys: Registered thermal governor 'step_wise'
[ 0.043786] cpuidle: using governor menu
[ 0.044539] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.044558] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.044848] Serial: AMBA PL011 UART driver
[ 0.064409] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.080116] raspberrypi-firmware soc:firmware: Attached to firmware from 2022 -03-24T13:20:54, variant start
[ 0.090129] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1 974127860b42e913d2374139ff5
[ 0.134705] Kprobes globally optimized
[ 0.137176] cryptd: max_cpu_qlen set to 1000
[ 0.139989] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.142268] SCSI subsystem initialized
[ 0.142521] usbcore: registered new interface driver usbfs
[ 0.142605] usbcore: registered new interface driver hub
[ 0.142681] usbcore: registered new device driver usb
[ 0.144559] clocksource: Switched to clocksource arch_sys_counter
[ 1.871962] VFS: Disk quotas dquot_6.6.0
[ 1.872099] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.872307] FS-Cache: Loaded
[ 1.872588] CacheFiles: Loaded
[ 1.872803] simple-framebuffer 3eaf0000.framebuffer: framebuffer at 0x3eaf000 0, 0x10a800 bytes, mapped to 0x(ptrval)
[ 1.872829] simple-framebuffer 3eaf0000.framebuffer: format=a8r8g8b8, mode=65 6x416x32, linelength=2624
[ 1.877881] Console: switching to colour frame buffer device 82x26
[ 1.882420] simple-framebuffer 3eaf0000.framebuffer: fb0: simplefb registered !
[ 1.893648] NET: Registered protocol family 2
[ 1.893912] IP idents hash table entries: 16384 (order: 5, 131072 bytes, line ar)
[ 1.895887] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.896043] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.896170] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.896367] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.896545] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.896607] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.896891] NET: Registered protocol family 1
[ 1.897637] RPC: Registered named UNIX socket transport module.
[ 1.897656] RPC: Registered udp transport module.
[ 1.897673] RPC: Registered tcp transport module.
[ 1.897690] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.899293] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counter s available
[ 1.904906] Initialise system trusted keyrings
[ 1.905169] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.914617] zbud: loaded
[ 1.916711] FS-Cache: Netfs 'nfs' registered for caching
[ 1.917600] NFS: Registering the id_resolver key type
[ 1.917684] Key type id_resolver registered
[ 1.917703] Key type id_legacy registered
[ 1.917859] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.917879] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering ...
[ 1.919194] Key type asymmetric registered
[ 1.919215] Asymmetric key parser 'x509' registered
[ 1.919275] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 49)
[ 1.919296] io scheduler mq-deadline registered
[ 1.919313] io scheduler kyber registered
[ 1.924440] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.927639] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656 x416
[ 1.931574] Serial: 8250/16550 driver, 1 ports
[ 1.931609] Serial: 8250/16550 driver, ISA IRQ sharing enabled
[ 1.933928] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.934405] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000 000(1024 MiB)
[ 1.935605] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f2 00000
[ 1.947813] brd: module loaded
[ 1.959785] loop: module loaded
[ 1.961546] Loading iSCSI transport class v2.0-870.
[ 1.963388] usbcore: registered new interface driver lan78xx
[ 1.963462] usbcore: registered new interface driver smsc95xx
[ 1.963491] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.164092] Core Release: 2.80a
[ 2.164114] Setting default values for core params
[ 2.164148] Finished setting default values for core params
[ 2.364564] Using Buffer DMA mode
[ 2.364584] Periodic Transfer Interrupt Enhancement - disabled
[ 2.364601] Multiprocessor Interrupt Enhancement - disabled
[ 2.364617] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.364647] Dedicated Tx FIFOs mode
[ 2.365180]
[ 2.365200] WARN::dwc_otg_hcd_init:1072: FIQ DMA bounce buffers: virt = b7504 000 dma = 0xf7504000 len=9024
[ 2.365240] FIQ FSM acceleration enabled for :
[ 2.365240] Non-periodic Split Transactions
[ 2.365240] Periodic Split Transactions
[ 2.365240] High-Speed Isochronous Endpoints
[ 2.365240] Interrupt/Control Split Transaction hack enabled
[ 2.365262] dwc_otg: Microframe scheduler enabled
[ 2.365326]
[ 2.365335] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.365348]
[ 2.365356] WARN::hcd_init_fiq:458: FIQ ASM at 807f7168 length 36
[ 2.365370]
[ 2.365378] WARN::hcd_init_fiq:496: MPHI regs_base at bb810000
[ 2.365406] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.365448] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.365502] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 2.365557] Init: Port Power? op_state=1
[ 2.365574] Init: Power Port (0)
[ 2.365955] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 5.10
[ 2.365978] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 2.365998] usb usb1: Product: DWC OTG Controller
[ 2.366018] usb usb1: Manufacturer: Linux 5.10.110-rpi-venus-4 dwc_otg_hcd
[ 2.366037] usb usb1: SerialNumber: 3f980000.usb
[ 2.366778] hub 1-0:1.0: USB hub found
[ 2.366849] hub 1-0:1.0: 1 port detected
[ 2.368085] dwc_otg: FIQ enabled
[ 2.368098] dwc_otg: NAK holdoff enabled
[ 2.368110] dwc_otg: FIQ split-transaction FSM enabled
[ 2.368127] Module dwc_common_port init
[ 2.368984] usbcore: registered new interface driver usb-storage
[ 2.369185] mousedev: PS/2 mouse device common for all mice
[ 2.370543] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.373038] sdhci: Secure Digital Host Controller Interface driver
[ 2.373056] sdhci: Copyright(c) Pierre Ossman
[ 2.373780] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.374062] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.376092] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.376512] hid: raw HID events driver (C) Jiri Kosina
[ 2.376671] usbcore: registered new interface driver usbhid
[ 2.376689] usbhid: USB HID core driver
[ 2.381275] Initializing XFRM netlink socket
[ 2.382024] NET: Registered protocol family 10
[ 2.383440] Segment Routing with IPv6
[ 2.383552] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.384402] NET: Registered protocol family 17
[ 2.384816] Key type dns_resolver registered
[ 2.385389] Registering SWP/SWPB emulation handler
[ 2.388932] registered taskstats version 1
[ 2.388973] Loading compiled-in X.509 certificates
[ 2.389779] Key type ._fscrypt registered
[ 2.389798] Key type .fscrypt registered
[ 2.389816] Key type fscrypt-provisioning registered
[ 2.401136] uart-pl011 3f201000.serial: there is not valid maps for state def ault
[ 2.401356] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.401453] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.503082] printk: console [ttyAMA0] enabled
[ 3.509869] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains drive r
[ 3.519673] sdhost: log_buf @ (ptrval) (f7507000)
[ 3.524733] Indeed it is in host mode hprt0 = 00021501
[ 3.637143] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.645869] of_cfs_init
[ 3.648431] of_cfs_init: OK
[ 3.652675] uart-pl011 3f201000.serial: no DMA platform data
[ 3.658740] Waiting for root device /dev/mmcblk0p3...
[ 3.700583] mmc0: host does not support reading read-only switch, assuming wr ite-enable
[ 3.711541] mmc0: new high speed SDHC card at address 0007
[ 3.717972] mmcblk0: mmc0:0007 SD32G 29.0 GiB
[ 3.725090] mmcblk0: p1 p2 p3 p4
[ 3.754633] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.755373] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. O pts: (null)
[ 3.761294] Indeed it is in host mode hprt0 = 00001101
[ 3.769284] VFS: Mounted root (ext4 filesystem) readonly on device 179:3.
[ 3.782236] devtmpfs: mounted
[ 3.836543] Freeing unused kernel memory: 1024K
[ 3.885142] Run /sbin/init as init process
[ 3.889243] with arguments:
[ 3.889254] /sbin/init
[ 3.889265] with environment:
[ 3.889276] HOME=/
[ 3.889287] TERM=linux
[ 4.024973] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcd Device= 2.00
[ 4.034525] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.042659] hub 1-1:1.0: USB hub found
[ 4.046583] hub 1-1:1.0: 5 ports detected
[ 4.364634] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.424989] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
[ 4.495060] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, b cdDevice= 2.00
[ 4.503433] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 4.513593] smsc95xx v2.0.0
[ 4.829887] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC LAN8700] ( mii_bus:phy_addr=usb-001:003:01, irq=POLL)
[ 4.841977] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb- 1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:23:f7:a3
[ 4.872753] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 4.919643] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. O pts: (null)
[ 4.944663] usb 1-1.5: new high-speed USB device number 4 using dwc_otg
[ 5.075310] usb 1-1.5: config 1 interface 0 altsetting 0 has an ignored endpo int with address 0x81, skipping
[ 5.085202] usb 1-1.5: config 1 interface 0 altsetting 0 has an ignored endpo int with address 0x2, skipping
[ 5.095052] usb 1-1.5: config 1 interface 0 altsetting 0 has an ignored endpo int with address 0x82, skipping
[ 5.104938] usb 1-1.5: config 1 interface 1 altsetting 0 has an ignored endpo int with address 0x3, skipping
[ 5.114725] usb 1-1.5: config 1 interface 1 altsetting 0 has an ignored endpo int with address 0x83, skipping
[ 5.124595] usb 1-1.5: config 1 interface 1 altsetting 1 has an ignored endpo int with address 0x3, skipping
[ 5.134357] usb 1-1.5: config 1 interface 1 altsetting 1 has an ignored endpo int with address 0x83, skipping
[ 5.134695] udevd[166]: starting version 3.2.9
[ 5.144216] usb 1-1.5: config 1 interface 1 altsetting 2 has an ignored endpo int with address 0x3, skipping
[ 5.158403] usb 1-1.5: config 1 interface 1 altsetting 2 has an ignored endpo int with address 0x83, skipping
[ 5.162736] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.168262] usb 1-1.5: config 1 interface 1 altsetting 3 has an ignored endpo int with address 0x3, skipping
[ 5.168280] usb 1-1.5: config 1 interface 1 altsetting 3 has an ignored endpo int with address 0x83, skipping
[ 5.175720] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.184461] usb 1-1.5: config 1 interface 1 altsetting 4 has an ignored endpo int with address 0x3, skipping
[ 5.194427] random: udevd: uninitialized urandom read (16 bytes read)
[ 5.200742] usb 1-1.5: config 1 interface 1 altsetting 4 has an ignored endpo int with address 0x83, skipping
[ 5.200760] usb 1-1.5: config 1 interface 1 altsetting 5 has an ignored endpo int with address 0x3, skipping
[ 5.236573] usb 1-1.5: config 1 interface 1 altsetting 5 has an ignored endpo int with address 0x83, skipping
[ 5.246931] usb 1-1.5: New USB device found, idVendor=0bda, idProduct=b720, b cdDevice= 2.00
[ 5.255359] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber =3
[ 5.262701] usb 1-1.5: Product: 802.11n WLAN Adapter
[ 5.263867] udevd[167]: starting eudev-3.2.9
[ 5.268204] usb 1-1.5: Manufacturer: Realtek
[ 5.276398] usb 1-1.5: SerialNumber: 00e04c000001
[ 5.569686] cfg80211: Loading compiled-in X.509 certificates for regulatory d atabase
[ 5.637919] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.639010] Bluetooth: Core ver 2.22
[ 5.671900] NET: Registered protocol family 31
[ 5.676551] Bluetooth: HCI device and connection manager initialized
[ 5.705665] Bluetooth: HCI socket layer initialized
[ 5.710618] Bluetooth: L2CAP socket layer initialized
[ 5.773231] Bluetooth: SCO socket layer initialized
[ 5.829955] usbcore: registered new interface driver btusb
[ 6.004006] usb 1-1.5: This Realtek USB WiFi dongle (0x0bda:0xb720) is untest ed!
[ 6.011579] usb 1-1.5: Please report results to Jes.Sorensen@gmail.com
[ 6.168892] usb 1-1.5: Vendor: Realtek
[ 6.172657] usb 1-1.5: Product: 802.11n WLAN Adapter
[ 6.177666] usb 1-1.5: rtl8723bu_parse_efuse: dumping efuse (0x200 bytes):
[ 6.184573] usb 1-1.5: 00: 29 81 03 7c 01 08 21 00
[ 6.189372] usb 1-1.5: 08: 50 07 05 35 10 00 00 00
[ 6.194169] usb 1-1.5: 10: 31 31 31 31 31 31 31 31
[ 6.198990] usb 1-1.5: 18: 31 31 30 02 ff ff ff ff
[ 6.203788] usb 1-1.5: 20: ff ff ff ff ff ff ff ff
[ 6.208607] usb 1-1.5: 28: ff ff ff ff ff ff ff ff
[ 6.213405] usb 1-1.5: 30: ff ff ff ff ff ff ff ff
[ 6.218241] usb 1-1.5: 38: ff ff 31 31 31 31 31 31
[ 6.223040] usb 1-1.5: 40: 30 30 30 30 30 f3 ff ff
[ 6.227860] usb 1-1.5: 48: ff ff ff ff ff ff ff ff
[ 6.232658] usb 1-1.5: 50: ff ff ff ff ff ff ff ff
[ 6.237477] usb 1-1.5: 58: ff ff ff ff ff ff ff ff
[ 6.242276] usb 1-1.5: 60: ff ff ff ff ff ff ff ff
[ 6.247095] usb 1-1.5: 68: ff ff ff ff ff ff ff ff
[ 6.251893] usb 1-1.5: 70: ff ff ff ff ff ff ff ff
[ 6.256713] usb 1-1.5: 78: ff ff ff ff ff ff ff ff
[ 6.261511] usb 1-1.5: 80: ff ff ff ff ff ff ff ff
[ 6.266327] usb 1-1.5: 88: ff ff ff ff ff ff ff ff
[ 6.271125] usb 1-1.5: 90: ff ff ff ff ff ff ff ff
[ 6.275945] usb 1-1.5: 98: ff ff ff ff ff ff ff ff
[ 6.280743] usb 1-1.5: a0: ff ff ff ff ff ff ff ff
[ 6.285562] usb 1-1.5: a8: ff ff ff ff ff ff ff ff
[ 6.290360] usb 1-1.5: b0: ff ff ff ff ff ff ff ff
[ 6.295175] usb 1-1.5: b8: 20 20 24 00 00 00 ff ff
[ 6.299973] usb 1-1.5: c0: ff 28 20 11 00 00 00 ff
[ 6.304793] usb 1-1.5: c8: 00 ff ff ff ff ff ff ff
[ 6.309590] usb 1-1.5: d0: ff ff ff ff ff ff ff ff
[ 6.314414] usb 1-1.5: d8: ff ff ff ff ff ff ff ff
[ 6.319245] usb 1-1.5: e0: ff ff ff ff ff ff ff ff
[ 6.324043] usb 1-1.5: e8: ff ff ff ff ff ff ff ff
[ 6.328862] usb 1-1.5: f0: ff ff ff ff ff ff ff ff
[ 6.333660] usb 1-1.5: f8: ff ff ff ff ff ff ff ff
[ 6.338494] usb 1-1.5: 100: da 0b 20 b7 e7 47 03 00
[ 6.343379] usb 1-1.5: 108: 13 ef f5 c7 43 09 03 52
[ 6.348284] usb 1-1.5: 110: 65 61 6c 74 65 6b 16 03
[ 6.353169] usb 1-1.5: 118: 38 30 32 2e 31 31 6e 20
[ 6.358073] usb 1-1.5: 120: 57 4c 41 4e 20 41 64 61
[ 6.362958] usb 1-1.5: 128: 70 74 65 72 00 ff ff ff
[ 6.367858] usb 1-1.5: 130: ff ff ff ff ff ff ff ff
[ 6.372743] usb 1-1.5: 138: ff ff ff ff ff ff ff ff
[ 6.377648] usb 1-1.5: 140: ff ff ff ff ff ff ff 0f
[ 6.382532] usb 1-1.5: 148: ff ff ff ff ff ff ff ff
[ 6.387438] usb 1-1.5: 150: ff ff ff ff ff ff ff ff
[ 6.392323] usb 1-1.5: 158: ff ff ff ff ff ff ff ff
[ 6.397224] usb 1-1.5: 160: ff ff ff ff ff ff ff ff
[ 6.402109] usb 1-1.5: 168: ff ff ff ff ff ff ff ff
[ 6.407013] usb 1-1.5: 170: ff ff ff ff ff ff ff ff
[ 6.411897] usb 1-1.5: 178: ff ff ff ff ff ff ff ff
[ 6.416801] usb 1-1.5: 180: ff ff ff ff ff ff ff ff
[ 6.421685] usb 1-1.5: 188: ff ff ff ff ff ff ff ff
[ 6.426589] usb 1-1.5: 190: ff ff ff ff ff ff ff ff
[ 6.431473] usb 1-1.5: 198: ff ff ff ff ff ff ff ff
[ 6.436379] usb 1-1.5: 1a0: ff ff ff ff ff ff ff ff
[ 6.441263] usb 1-1.5: 1a8: ff ff ff ff ff ff ff ff
[ 6.446168] usb 1-1.5: 1b0: ff ff ff ff ff ff ff ff
[ 6.451052] usb 1-1.5: 1b8: ff ff ff ff ff ff ff ff
[ 6.455971] usb 1-1.5: 1c0: ff ff ff ff ff ff ff ff
[ 6.460856] usb 1-1.5: 1c8: ff ff ff ff ff ff ff ff
[ 6.465760] usb 1-1.5: 1d0: ff ff ff ff ff ff ff ff
[ 6.470645] usb 1-1.5: 1d8: ff ff ff ff ff ff ff ff
[ 6.475549] usb 1-1.5: 1e0: ff ff ff ff ff ff ff ff
[ 6.480434] usb 1-1.5: 1e8: ff ff ff ff ff ff ff ff
[ 6.485339] usb 1-1.5: 1f0: ff ff ff ff ff ff ff ff
[ 6.490223] usb 1-1.5: 1f8: ff ff ff ff ff ff ff ff
[ 6.495134] usb 1-1.5: RTL8723BU rev E (SMIC) 1T1R, TX queues 3, WiFi=1, BT=1 , GPS=0, HI PA=0
[ 6.503666] usb 1-1.5: RTL8723BU MAC: 00:13:ef:f5:c7:43
[ 6.508919] usb 1-1.5: rtl8xxxu: Loading firmware rtlwifi/rtl8723bu_nic.bin
[ 6.517020] usb 1-1.5: Direct firmware load for rtlwifi/rtl8723bu_nic.bin fai led with error -2
[ 6.525681] usb 1-1.5: request_firmware(rtlwifi/rtl8723bu_nic.bin) failed
[ 6.532476] usb 1-1.5: Fatal - failed to load firmware
[ 6.537725] rtl8xxxu: probe of 1-1.5:1.2 failed with error -11
[ 6.543681] usbcore: registered new interface driver rtl8xxxu
[ 6.642719] vc_sm_cma: module is from the staging directory, the quality is u nknown, you have been warned.
[ 6.656061] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.662566] [vc_sm_connected_init]: start
[ 6.667910] [vc_sm_connected_init]: installed successfully
[ 6.688329] mc: Linux media interface: v0.10
[ 6.754453] videodev: Linux video capture interface: v2.00
[ 6.815207] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 6.815214] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 6.815752] bcm2835_mmal_vchiq: module is from the staging directory, the qua lity is unknown, you have been warned.
[ 6.854869] bcm2835_v4l2: module is from the staging directory, the quality i s unknown, you have been warned.
[ 6.856915] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.878899] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.892127] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev /video13
[ 6.897046] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.907127] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de v/video14
[ 6.907157] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.920840] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de v/video15
[ 6.923399] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.936389] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.936532] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/ video16
[ 6.946908] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.949819] bcm2835-isp bcm2835-isp: Register output node 0 with media contro ller
[ 6.956714] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.965006] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr oller
[ 6.971994] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.977667] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr oller
[ 6.984033] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.997615] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr oller
[ 7.008761] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev /video20
[ 7.017245] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /de v/video21
[ 7.025760] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /de v/video22
[ 7.034247] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/ video23
[ 7.042169] bcm2835-isp bcm2835-isp: Register output node 0 with media contro ller
[ 7.049755] bcm2835-isp bcm2835-isp: Register capture node 1 with media contr oller
[ 7.057435] bcm2835-isp bcm2835-isp: Register capture node 2 with media contr oller
[ 7.065091] bcm2835-isp bcm2835-isp: Register capture node 3 with media contr oller
[ 7.073087] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.268017] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null)
[ 8.312456] urandom_read: 2 callbacks suppressed
[ 8.312467] random: dd: uninitialized urandom read (512 bytes read)
[ 8.485134] random: eeprom: uninitialized urandom read (24 bytes read)
[ 8.634692] Under-voltage detected! (0x00050005)
[ 9.340078] watchdog: watchdog0: watchdog did not stop!
[ 9.810507] random: dbus: uninitialized urandom read (24 bytes read)
[ 10.057506] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[ 10.099259] random: dbus-daemon: uninitialized urandom read (12 bytes read)
[ 12.028326] random: crng init done
[ 12.648178] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 12.655313] device eth0 entered promiscuous mode
[ 12.815845] smsc95xx 1-1.1:1.0 eth0: Link is Down
[ 14.956956] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control off
[ 14.964882] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 14.984324] IPv6: ADDRCONF(NETDEV_CHANGE): ll-eth0: link becomes ready
[ 15.052104] 8021q: 802.1Q VLAN Support v1.8
[ 18.204292] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null)
[ 33.754627] cam-dummy-reg: disabling
driver
