mavo avatar image
mavo asked
MP increases the frequency -the MPPT in parallel does not reduce the Power - what happens?
Hello, its my first time here. The main part of my question should be in the headline? The main is off.
The inverter works( batteries are chared) . What happens, if there is a fault in the MPPT, and it is not reducing its power automaticaly ?
Does the inverter stops his operation without other problems in a short time, or will its power become smaller, controlled by the higher temperatures of the inverter? Does anyone knews about this protection case? Grüße Matthias
knowledge base
greendovefarms avatar image
greendovefarms answered ·
Hi Mavo
Are you using a PV-AC inverter as well as a DC to AC inverter ?
Eg Fronius (or similar with frequency shifting) and a Multiplus ?
What is the makeup of your system ?
mavo avatar image
mavo answered ·
Hi G.D.Fs, I like the "behavior" of the MP2s and the fact,that I found them - but as an electronic one I would like to know more about them. - to make use of it with a great MTBF
