lex2k0 avatar image
lex2k0 asked
AES on Quattro II not properly working
It seems that the AES does not start properly on the Quattro II, up to Firmware 508.
I have a standbye usage of 39W as output on the Quattro and so I set the limit to 44W, which is the lowest configurable setting for the AES to start. But it was not starting. Later I made tests. Also with a usage of 9W it was not starting. So I increased the start usage to 69W and then AES started. I changed the usage to 12W, and AES was no longer starting. Increased it to 90W with a 12W usage and the AES was starting.
So somehow the behavior of the system is not understandable. Why it is not starting on a usage of 9W if the setting is 'lower than 44W'
It seems there is a problem in the software or the logic behind.
Can you please fix it?
Kind regards
Alexander
aes
