- IHi everyone I want to set up my ESS but I dlike to know what will put her on my Dc input shut down , dc input low restart and dc input pre alarm I have a Victron Gel Batteries 220A so can you help I have 48 V system
Hi @Abdelmjid
I believe if you add the ESS assistant it will get you to enter the type of battery you have. If you select your type from the drop down it will populate these voltages with the battery default setitngs. I would then just confirm those look correct vs what's included in the battery manual from the manufacturer (victron)
64 People are following this question.
