abaco avatar image
abaco asked
MK3 USB stopped working (3different systems + 2 different laptops)
Hey, anybody has the same issue? Did configurations 3 days ago on 2 different systems with 2 individual MK3 - everything worked. Today I got the usb driver error. Reinstalled everything, manually updated the drivers - still the same problem. Changed laptop other windows, same story - what can I do now?
mk3-usb
Alexandra avatar image
Alexandra answered ·
@abaco
If you are comfortable, you crack it open sometimes through handling the cable breaks off the board inside. Needs a re solder.
abaco avatar image abaco commented ·
2 different adapters - same problem, same day aftervictron app update - other problem
Alexandra avatar image Alexandra ♦ abaco commented ·
It doesn't seem to be a Victron software/program/driver problem. There aren't any other complaints here on the forum. I personally have not had any problems.
If anything you can use a smart phone and an otg.
You can test the MK3 by plugging it into the ve bus on the GX. It should be recognised as an inverter.
abaco avatar image abaco Alexandra ♦ commented ·
Thank you for your help, problem just solved - I tried different MK3 and different PCs but the problem was the usb cable :-)
