jmeisl avatar image
jmeisl asked
Batterie loading with onla 10% from CCL – Charge Current limit
Hello,I don't understand the throttling of the battery charging current.Although the “CCL – Charge Current limit (A)” is 200A per battery, the battery is only charged with 22A.
I have 2 batteriepacks a. 16x280Ah LiPoFe with Daly-BMS 250A.
BMS-drivers Louisvdw/dbus-serialbattery over RS232
aggregation with Dr-Gigavolt/dbus-aggregate-batteries.
Fronius Symo 6.0 and Victron MPPT 450/100
What is the determining factor for the battery charging current with a Multiplus?
Why does the system note use the „CCL – Charge Current limit“
Best regards
battery chargingESS
