rampit avatar image
rampit asked
Wiring diagram
I have 4 12v batteries 110amp in series giving 24v to run a miniature electric loco
I am looking for a wiring diagram
4 12v Batteries in series one 24 v charger a BMV-712 Smart Battery monitor also using Victron Energy Battery Balancer a Buck converter 24v to 12v to run 12 accessories i.e. lights
The output from the batteries powers a Idrive speed controller
Battery Balancer
Sarah avatar image Sarah commented ·
Four 12 v batteries in series is 48 volts not 24 volts ….
iammotorhomeless avatar image
iammotorhomeless answered ·
@Rampit
have a look at image 12 in the BMV-712 Smart Battery monitor set up giude
https://www.victronenergy.com/upload/documents/Quick-Install-Guide-BMV-712.pdf
just add your second pair as I have shown here
add the Battery Balancer to the main negative, the same positive as your midpoint and then to the main positive.
add the charger and loads as shown above
hope this helps
rampit avatar image
rampit answered ·
Thank you just what I needed
iammotorhomeless avatar image iammotorhomeless commented ·
@Rampit your welcome
@Rampit are they LifePo4 batterys ??
this is 6, 2 by 3
but I would wire 2 by 2 the same way
rampit avatar image
rampit answered ·
12 v 110 amp Lead Acid leisure batteries
rampit avatar image
rampit answered ·
I am new to these Victron products so I need very basic help
Where in a four battery series wiring does the Smart monitor go and the Balancer is this one or more also connection of one 24v battery charger
Sorry all new to me novice in setting up such a configeration
cardy01 avatar image
cardy01 answered ·
As commented above 4 12v batteries in series = 48v not 24
Start here www.victronenergy.com/upload/documents/The_Wiring_Unlimited_book/43562-Wiring_Unlimited-pdf-en.pdf
Once you have decided how to wire your 4 batteries I'm sure many people will help with the fine detail ......
please read the question
"giving 24v to run a miniature electric loco"
so, 2 by 2 for a 24V system :)
