bernitm avatar image
bernitm asked
Feed-in excess solar charger power option does not show up
cerbo9.JPGcerbo10_1.JPGHi Community, I have one Multiplus II 48/5000/70-48 v507, Cerbo GX v3.12 and MPPT VE.Can 250/100 rev2 v3.14 in place and have an issue that with the option Feed-in excess solar charger power that it does not show up in remote console. The system is up and running - but I am missing this option. What could be the reason ?
kind regards
Bernhard
feed-in
gazza avatar image
gazza answered ·
Do you have the ESS assistant loaded?
bernitm avatar image bernitm commented ·
Yes, ESS Assistant is loaded - exported config see here:
REGISTERKARTE: Assistenten-Konfiguration
ESS (Energiespeicherungs-System) (Größe:978)
*) System uses LiFePo4 with other type BMS
(This can be either a BMS connected via CAN bus or a BMS system in which the
batteries are protected from high/low cell voltages by external equipment.)
*) Die Batteriekapazität des Systems beträgt 300 Ah.
*) Sustain-Spannung 48.00 V.
*) Abschalt-Spannung für einen Entladestrom von:
0,005 C= 44.80 V
0,25 C= 44.80 V
0,7 C= 44.80 V
2 C= 44.80 V
*) Wechselrichten wieder zulassen, wenn die Spannung 1.20 V über Cut-off(0) liegt.
*) Relevante VEConfig-Einstellungen:
- Batteriekapazität 300 Ah.
- PowerAssist nicht ausgewählt
- Lithium-Batterien ausgewählt
- Dynamische Strombegrenzung nicht ausgewählt
- Lagerungsmodus nicht ausgewählt
iammotorhomeless avatar image
iammotorhomeless answered ·
@bernitm have you set it up in VE config ??
iammotorhomeless avatar image iammotorhomeless bernitm commented ·
Got me... it should be visible
have you tried another firmware on the Cerbo GX. have you just installed v3.12
try v3.10
might be a question for @Guy Stewart (Victron Community Manager) or @mvader (Victron Energy)
they might have seen this before
mjs500 avatar image
mjs500 answered ·
scroll down this page set grid setpoint to negative number ( - 780w for example )
to limit feed- in go to grid feed -in page and enable limit system feed-in and set max feed in
I do not want to configure any limit - to limit feed-in - even when I could configure it so high, that I will never reach it. For what reason I should set the grid setpoint to minus value ? I didn't get the trick behind this setting.
But all this settings - will not bring me the option visible I am looking for. I have already tested it.
kind regards
gazza avatar image
gazza answered ·
I am not sure I am seeing what is missing? Looking at your cerbo10.jpg You already have it selected? DC-gekoppelte PV.... that is "Feed-in excess solar charger power" ?
Hi, so you mean the menu of the remote console has changed ? because earlier this menu was on top(3rd place) of the remote console. "Feed-in excess solarcharger power" And I can not find this option in my environment (remote console).
