everlongsailing avatar image
everlongsailing asked
Orion-Tr Smart DC-DC Charger Non-Isolated not working.
Victron Orion-Tr Smart DC-DC Charger Non-Isolated
We have 2 of these on our boat and this year when we recommissioned, I reconnected them and all was well for about 2 days. Then they both dropped from the Victron connect app and are not charging the house bank.
I have checked and there is 12.57 volts on the input and 13.2 volts on the output (this is as it has been for the past 2 years). I also noticed that both the blue and green LEDs are flashing very quickly. (they are very dim as well)
I have tried disconnecting the power for several minutes and restarting but I get the same result each time with the LEDs flashing very quickly. I did search for this problem and have seen similar question but no solutions. Is it possible to physically connect to this device to check it out further?
Thanks
orion-tr smart
kevgermany avatar image
kevgermany answered ·
Sounds like your input is too low. Either weak source or wiring faults/resistance/corrosion.
A screen shot from Victron connect would help.
