Simple question. The manual suggests the Orion-Tr Smart DC/DC charger (mine is a 12|12-30) should be nearer to the auxiliary battery then to the car battery. But is it necessary or can I put the Orion next to the battery at about 5 meters?
I'm curious where you see in the manual that it should be closer to the auxiliary battery? Generally speaking I'd argue the reverse would be true - there's higher current and lower voltage on the input side, so circuit length should be minimized on the input side more than the output side.
That said, your proposed 5m distance = 10m round-trip distance, which would require rather exorbitantly oversized cabling to combat voltage drop over such a long circuit, so the ideal position is definitely centered between the two batteries if not justified slightly toward the start battery.
This picture: https://www.victronenergy.com/media/pg/Orion-Tr_Smart_DC-DC_Charger_-_Isolated/en/image/164ad38da13c00.jpg
But when I looked up the picture I noticed the answer is in the text (4.1): "Mount close to the battery, but never directly above the battery (in order to prevent damage due to gassing of the battery)." I have a old-style alternator so the voltage is always high when the engine is running.
Orion-Tr Smart Dc to DC Charger, Alternator Victron Energy
__________
Orion-Tr Smart DC-DC Charger Isolated 12 / 24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Datasheet
Orion-Tr Smart DC-DC Charger Isolated 12 /24 Volt - Online Manual
__________
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Product Page
Orion-Tr Smart DC-DC Charger Non-Isolated 12 /24 Volt- Datasheet
__________
55 People are following this question.
