sneakycoon avatar image
sneakycoon asked
Just received mppt 75/15 and error 119
Hi, I just received my smartsolar 75/15 and after updating the 2 firmwares, each time i connect it give me:
Err 119 - Settings data lost
According manual
The charger cannot read its configuration, and stopped.
This error will not auto-reset. To get it working again:
  1. First, restore it to factory defaults.
  2. Disconnect the charge controller from all power-sources
  3. wait 3 minutes, and power up again.
  4. Reconfigure the charger.
But it doesn't help, when i first connected, it asked me to update some firm to 2.22 i think and other firm to 1.39 if i remember well, is there anything else i could do? Should i return it already?
Thanks
MPPT Controllers
wkirby avatar image
wkirby answered ·
I wonder what PIN code you have used to pair the devices?
They don't like 0000 or 1234 (or any 4 digit code for that matter). Could you try and re-pair the devices and use a six digit PIN instead 000000.
I hope that will help.
sneakycoon answered ·
thanks for you so quick answer, actually i didn't used any pin code, i just clicked pair and the system updated itself, is that matter?
EDIT: after multi factory reset, it came back to life
But is it normal that there is some kinda of sand going out of the device ? Like plastic sand, it seems that the device is full of it , i bought it from amazon
wkirby avatar image wkirby ♦♦ commented ·
Yes, it is filled with a white sand type stuff. There may be a small amount that didn't quite get sealed in at the factory, but there shouldn't be a lot.
sneakycoon avatar image sneakycoon wkirby ♦♦ commented ·
thx for your answer ;)
