gdhondt avatar image
gdhondt asked
Running Dynamicc ESS, Cant reach the maximum Charge Current Level
My setup:
  • 3 phase Multiplus II 48/5000
  • 45kWh Battery capacity
  • Running Dynamic ESS
  • Max grid current 3X 25A = 17000Watt
I have a question about the maximum charge current of my system. My system is not charging maximum watts/amps what the system is able to do. The multis should be able to charge 3X70A=210A. While the system in the VRM does not reach 180A of charging current.
I have the following options/settings enabled/disabled:
Parameters from my BMS (seplos)
Even if i make my 'grid setpoint' 14000 watts. It still charge my battery with maximum of 9500 watts.
Does anyone have any advice on what I can check? With the Dynamic ess function, I want to use my system as optimally as possible
charge current limit
mableeker avatar image
mableeker answered ·
What are your settings for DESS (in VRM or Nodered). The to/from grid and to/from battery variables are determining the charge amps, not the grid setpoint for as far I know now.
Dirk-Jan Faber (Victron Energy) avatar image
Dirk-Jan Faber (Victron Energy) answered ·
Can you set your systems VRM logging interval to 1 minute instead of 15 minutes.? That way we get some more data to analyze.
4 comments
gdhondt avatar image gdhondt commented ·
Hi Dirk-jan,
I have set the vrm logging interval to 1 minute. :)
My Dynamic Ess Settings are now set to my maximum charge capacity (9800 watts) otherwise my DESS charge calculations doesn’t match the reality.
Dirk-Jan Faber (Victron Energy) avatar image Dirk-Jan Faber (Victron Energy) ♦♦ gdhondt commented ·
I did talk to one of my colleagues and he said that the 70A max is at 25°C, and it derates pretty quickly from there. It is pretty typical to see 63A or so per unit (10% down), multiply by 3 and you are around 180A.
gdhondt avatar image gdhondt Dirk-Jan Faber (Victron Energy) ♦♦ commented ·
Hi Dirk-jan.
Still have the issue with reduced charging current
I noticed that if I make my battery monitor “multiplus” visible. Then you see the system thinks it is charging the battery with 10000 watts.
So it looks like there is a bug in the charging monitoring. That’s why the system never reach the maximum charge current of 210A
I think that My reduced charging current is not temp related.
I’m running DESS. But DESS doesn’t affect the max charging current by switching DESS on or off.
The smartshunt is more accurate than the multiplus.
160A out of the potential of 210A, is 76%, which suggests an operating temperature of around 60°C. Also see here: https://www.victronenergy.com/upload/documents/Output-rating-operating-temperature-and-efficiency.pdf
Note that the temperature is the temperature within the Multiplus and not the ambient temperature.
