stevebriggs avatar image
stevebriggs asked
Orion Smart DCDC charger 12v|12v 30a settings
Can somebody advise the settings required for an Orion Smart dcdc charger 12v12v 30a connected to a smart alternator and two Victron Lithium 100ah batteries as in:
Function: Charger or Power Supply?
Battery Settings?
Engine Shutdown Detection Settings?
Input Voltage Lock-Out Settings?
Plus any other parameters that need to be applied.
Thanks
dc-dc charger
kevgermany avatar image
kevgermany answered ·
The system has thrown up some links below, which should explain things. There's also an excellent manual with the charger
Please come back to us with what's not clear from them.
You want to charge your batteries -> select charger
You have lithium batteries -> select the lithium algorithm
Any other settings you have to test at YOUR car, it's hard to recommend settings for that.
stevebriggs avatar image stevebriggs commented ·
Hi Matthias - the van is a Mercedes Sprinter 2021 and the leisure batteries are not charging for some reason through the dcdc charger from the engine. The current settings are:
Battery settings:
Battery reset: User defined
Charger enabled
Absorption voltage: 14.40v
Float voltage: 13.50v
Bulk time limit: 10h
Re-bulk offset voltage: 0.10v
Adaptive absorption time: switched off
Fixed absorption time: 2h
Engine Shutdown Detection settings:
Alternator type: Smart
Start Voltage: 14.00v
Delayed start voltage: 13.30v
Delayed start voltage delay: 120s
Shutdown voltage: 13:10v
Input voltage lockout settings:
Bell icon 12.5v
Bell icon with diagonal line through 12.8v
Hopefully, there might be discrepancy in the above settings that somebody can spot?
