chris-smith avatar image
chris-smith asked
Venus OS missing commands
While trying to set up a Raspi4 and Expander Pi board for analog level sensors I tried to check which services were running. Neither systemct1 or services seem to exist as a command in Venus OS3 .2 . Is there a way to install these commands or is there another way to check which services are running?
Venus OS v3.00-32
Kevin Windrem avatar image
Kevin Windrem answered ·
Venus OS does not use systemd to run services. Rather it uses a system called daemontools:
https://cr.yp.to/daemontools.html
You can use svstat /service/* to get the status of all services running (or not) on the system.
Mike Dorsett avatar image
Mike Dorsett answered ·
Venus OS v3.00 – Generator start/stop improvements, ESS Peak shaving
