soltron365 avatar image
soltron365 asked
-ve Value on Victron Energy Meter from battery
-ve-value-into-meter.pngAnybody have this issue4 x Victron Multiplus 48/5000
50 kWhr Fwon batteries
2 x 6 kWatt Fronius primo
When running PV in self-consumption it works fine
Only when no PV problem arises i.e. at night
New Firmware Victron GX and ESS
I get a negative value on the Victron Energy Meter when we go into ESS self-consumption.- Watts
With Battery life SOC 50%
When I select Keep batteries Charged it charges from the grid an a positive value from grid so meter is working fine
I have a suspicion.
Firmware version on GX device ?
Or the New Ess Function
Use Battery power for Essential loads or entire house – and either selection it still gives a negative Value as though the battery is feeding back into the grid
Running V 3.10 on GX
Multiplus v506
ess discharging
Mike Dorsett avatar image Mike Dorsett commented ·
Looks like you are pumping power back into the grid...
There is a max export power setting, you could try setting this to a near zero figure.
