I am logged into Beta VRM but if I check the Settings submenu the link for "Dynamic ESS" is not shown. What am I missing?
On my Beta version is Dynamic ESS available, but the dashboard (last step?) does not have the button for the next step. Who can help me?
Hi, do you mean the "Dynamic ESS" menu in the remote console? because thats what iam missing as well.. after some reading i found that only victron aproved grid meters are supported.. iam using a P1 ESP module for my grid metering.. maybe this has something to do with it? Wich kind of grid meter do you use?
I am using the RS485 version of the EM24 - which is interestingly NOT listed on the slide listing the models available from Victron in the DESS Webinar.
It turned out to be the older 3.01 firmware version. For some reason I always read 3.10 while it was still at 3.01
After updating to 3.10 the menu option appeared.
In order to function properly and knowing how much energy is flowing a supported energy meter is needed. Basically any energy meter that is supported on the GX device will suffice. See the energy selection guide for supported meters.
Things like the Dutch P1 meter are not sampling fast enough and not supported right now.
After filling in Dynamic ESS i get a green confirmation button. When i go back to the dashboard the control panel on the right top side is not appearing whilst still in beta vrm mode. I installed it on a Multiplus GX.
What can i do to get the setting button (step 5 of the manual).
I see this, and have to go into setting and then out egain before it fixes itself (this has been happening for a week max, was fine before)
I have the same problem on 2 installations. 2 others are working perfect. All4 same hardware, original victron meters ,same settings ,latest firmware. I have no clue how to fix this ?
@Dirk-Jan Faber (Victron Energy) , Can you check my installations too please ?
2 are working fine : the other 2 have this problem. ( 1 of the 2 probleminstallations is currently off-line because we have to finish it ). Thanks !
Not 100% sure if I am looking at the correct system, but noticed that the offline one has a very high battery cost of 0.43 €/kWh. For DESS, this makes it too expensive to use the battery. I think you are missing a zero in the expected battery cycles.
I cannot get the option for Dynamic ESS to show up in the VRM-portal.
I've updated to 3.20~33
I do log into the BETA VRM.
The Energy meter is on the list over compatible options (EM540)
CAnnot fanthom what it is that I am missing, have got it up and running on another system, the only difference being that this one is a 3-phase system.
Any ideas? Would be much appreciated.
I'm trying to get Dynamic ESS, but can't find it in betavrm.
Energy meter is EM24 Ethernet.
Could you help?
Your system type is set to Hub-1 (as shown by the logging on the diagnostics tab). Dynamic ESS requires ESS or Hub-4. So you need a different ESS assistant, which can be configured through VE.Configure.
See https://www.victronenergy.com/media/pg/Energy_Storage_System/en/index-en.html for more information on that.
So if you are planning to include Multi RS 6000 to the list of alpha-beta testers, please, include my setup, will be happy to help
what all must by done for seeing DESS on beta VRM? cerbo sw 3.01, MplusII and still nothing to see. What is wrong? or what is necessary?
47 People are following this question.
