rodney avatar image
rodney asked
Panel cable connection
Hi, Newbie here. Just received a 50 W victron panel. Does the cable connection get crimped, please see picture? I assume it doesn't connect beneath the screw head, as it is partially soldered.
Also, the RH connector looks slightly bent. Will this be ok?
Thanks
solar
sean avatar image
sean answered ·
Is that a brand new panel ? - I've never seen or purchased a Victron panel but I'm surprised you have to terminate you own connection wiring at the diode block - I'd expect them to come with +/- trailing leads.
7 comments
rodney avatar image rodney commented ·
Thanks Sean, yes, it is new. According to the seller, all Victron panels <80W are like this.
sean avatar image sean rodney commented ·
Very odd, they are crimp connections - but getting access with the tool might be less than easy - so a combination of crimping with pliers and soldering seems to be required.
It does look like the RH cells tab is at a rather jaunty angle, assuming it performs electrically it should be fine.
rodney avatar image rodney sean commented ·
Cheers Sean. I wasn't sure if the crimp connection is for the insulation. I will measure the open circuit voltage and short circuit current, and if not in spec return to vendor. Maybe crimp and solder is a possibility.
Jono (Victron Energy Staff) avatar image Jono (Victron Energy Staff) ♦♦ rodney commented ·
If you take a look at the relevant datasheets, this is correct.
BlueSolar Polycrystalline Panels: 20w - 60w
https://www.victronenergy.com/upload/documents/Datasheet-BlueSolar-Polycrystalline-Panels-EN.pdf
BlueSolar Monocrystalline Panels: 20w - 55w
https://www.victronenergy.com/upload/documents/Datasheet-BlueSolar-Monocrystalline-Panels-EN.pdf
rodney avatar image rodney Jono (Victron Energy Staff) ♦♦ commented ·
Thanks. Are you suggesting it should be delivered non -wired? If so, should it be crimped, or crimped and soldered?
thanks
No, they are not pre-wired for the panel sizes I listed above.
It would appear only the 55w and above panels are pre wired along with MC4s.
