tcason avatar image
tcason asked
battery busbar wire configuration
I am installing positive and negative busbars to assist in properly balancing my 24v two bank set of 4 220ah 12v Victron Gel batteries. Should I connect all of the charging source cables and positive load output wires to the positive busbar and all of the negative ground wires to the negative busbar with only + and - battery connector cables leading from the busbar to the batteries themselves?
Battery Balancer
kai avatar image
kai answered ·
that's a fairly typical installation. don't forget the fuse between the battery and the busbar.
