drparker151 avatar image
drparker151 asked
bug. Solar and wind priority displaying negative amps on line1 AC input.
I've enable solar and wind priority, when only a small AC load is on the system. It is showing negative amps on line 1 input of 2x120 Multiplus.
Hughes Watchdog EMS is showing a draw of .6amps but the multiplus is showing a -.7 like it is back feeding the grid, even though Grid country is set to none.
If I disable Solar and wind priority Line goes back to a positive amp draw.
Appears to be some kind of bug.
solar wind priority
drparker151 answered ·
Interesting. it took two days for battery voltage to drop all the way to 13.0, once it hit this L1 has stayed positive even after solar brought the voltage higher.
