raww avatar image
raww asked
Multiplus-II ESS instability
my configuration:
MultiPlus-II 48/5000, 2x150/100 MPPT + 150/70 MPPT all VE.Can, Cerbo GX, Lynx Shunt, DIY LiFePO4 13,6kWh, JK BMS no communication.
Grid connected to AC-In 1
All components on latest Firmware
ESS Configuration
Problem:
The power plant půroduces and supplies to the grid. The supply is randomly interrupted, but immediately resumed.
Why? Sky is clear, without load change.
Video: https://youtu.be/6cmoMfTLbAE
I am out of ideas. Please advise where the problem may be.
Multiplus-IIESS
elvis avatar image
elvis answered ·
Do you have "Limit Grid Feed In" enabled?
raww avatar image
raww answered ·
Yes, limit is set to 9900W.
It is the same with "Limit Grid Feed In" disable.
elvis avatar image elvis commented ·
Turn that off and see if it solves the issue.
