schollex avatar image
schollex asked
Multiplus AC-in disbalanced
my installation are 2 Multiplus II 3000 (on L1 and L2) with ESS.
The problem is that inverting (= feeding in to AC-in) is sometimes disbalanced, this means that both MPs should produce the same amount of power, but they don't:
You see both MPs were producting the same amount of energy in the morning during moring.
At ~10:00 the MP on L1 starts to produce much more energy than the MP on L2.
At ~12:00, I turned off+on both MPs via Venus-OS - then both MPs again produce the same amount of power.
As the disbalancing can be "repaired" by switching off+on the MPs, I think this clearly indicated that there is a bug within Venus-OS. I run v3.01.
Do you know this problem and does anybody know a solution?
Bye
Alex
Multiplus-IIESS
schollex answered ·
I'm still facing this problem. meanwhile on Venus OS v3.3 and on 4 differnt installations.
They all us 2 Multiplus (L1+L2) with ESS and freuquently get disbalanced during feeding-in exceeding power.
As workaround, if disbalance becomes too great, a NodeRed-flow disables feedin for 3 sec and then enables feedin again. This makes both MPs balanced again.
Duivert NL avatar image
Duivert NL answered ·
hi, i don't think its a problem, looks normal, maybe not the same setup but my system (3 phase multiplus 2 ESS) is doing exactly the same thing...
schollex avatar image schollex commented ·
For me, it's a problem because the Multis heat up differently. I would like to have balaced multis which is my ESS-setup (Multiphase regulation: total of all phases).
Duivert NL avatar image Duivert NL schollex commented ·
yes mine heat up differenly too,
multiphase regulation is not for equaling the grid with grid feed in, its for equaling the load on the multi's, see:
https://www.victronenergy.com/media/pg/Energy_Storage_System/en/multiphase-regulation---further-information.html
