solartronics avatar image
solartronics asked
Victron 450/200 with ESS limiting eventhough battery is low and load is high
Hi everyone.
I have a system with a Victron Quattro 48/15000, 1x Victron 450/200, 1x Victron 250/60, 1x Freedom Won 30kWh running ESS.
The system was running fine for almost a year then suddenly the 450/200 started throtteling down eventhough the battery SoC is at about 35% and the load is high. It starts up fine in the mornings, runs for about half an hour then reduces to zero. I have tried every potential combination of ESS& DVCC settings without luck. Not sure if it is getting signals from the FW to throttle down, which is strange because the voltage is still far below 55.8V, but the 250/60 running on Ve direct is running perfectly fine.
-Grid feed enabled
-ESS tried all modes (Keep Batteries Charged, With& Without Battery life)
Firmware
-450/200 v1.11
-Cerbo v3.01
-250/60 v1.61
Any recommendations/ suggestions would be appreciated.
ESSDVCCrs450
