max-payne avatar image
max-payne asked
Multiplus ESS - Select Multiplus DC over BMS values
Simple ESS Question:
Pylontech US5000 connected (which is a 15s battery) with the CAN port. Everything works perfectly.
Now the Pylontech was expanded by a second offbrand battery pack in parallel. Everything works as expected but I want to set the Battery current sensing source as the DC current of the MultiPlus II and not the batteries BMS values.
Since a second pack is connected in parallel the charging power and amps is off by a factor of 2. Discharge limit is working correctly since that is limiting the AC feedback of the Multiplus.
Summary:
I want the Battery current and power to equal the DC current the Multiplus is measuring and not the values from the pylontech CAN BMS.
Is there a way to set that as the source for Battery:
Instead of the CAN BMS?
ESSess settingsess discharging
nickdb avatar image
nickdb answered ·
You will be better off disconnecting the BMS altogether and using a shunt instead.
Also be aware that your Pylon warranty has gone out the window by mixing brands.
max-payne answered ·
Disconnecting the pylontech BMS CAN would also work I suppose as the charging curve set in veconfig is perfect for the pack. Pylontech is outside warranty period already anyways.
I already have different brands of 15s lifepo4 towards the Lynx distributor so adding a
Lynx Shunt looks like a good idea!
SOLVED!
What is ESS training video
ESS Quick Installation Guide
ESS design and installation manual
