fordens avatar image
fordens asked
Wind turbine controller to integrate with Lynx BMS?
Hi all,
Getting my hand on the Leading Edge LE-600 wind turbine I would like to connect it to my BMS.
This is a 3 phase wind turbine, so needs a rectifier to a standard DC which I can easily find. But then, I cannot find a dedicated wind controller or easy way to connect to my system.
Anyone a suggestion? MPPT controller like Victron? Dedicated wind charge controller? Brand or model? Any help is very welcome. Cheers
Hydro and Wind Power
hjohnson avatar image
hjohnson answered ·
You will want to find a dedicated regulator for wind turbines. The problem with using something like an MPPT is they go open-circuit once the battery is full. This is fine on a solar panel, but with a wind turbine it will let your turbine freewheel and potentially overspeed. For a wind turbine you need either a diversion regulator (which will dump excess energy into a diversion load) or a dedicated wind controller that will simply short out the turbine, causing it to stall out and stop generating any significant power.
fordens answered ·
Thanks for your reply,
The Leading Edge website shows a setup with charge controller with load dumper in the same time, but I’m not sure I can connect it directly to BMS Distributor bar? Any opinions? This set up looks like more for classic lead acid batteries but not for lithium ones.
nesswill avatar image
nesswill answered ·
Looking at the website, dose this help? you have this?
You can do this..
and buy Charge Controller
Hope this helps.
fordens avatar image fordens commented ·
You probably did not read my question.
Once again, the setup on website shows direct connection to the lead acid of flooded batteries (Trojan on the pictures), either with a DL-300 controller by Leading Edge (with integrated heat dumper) or with Tristar 60 with separate dumper.
My question was: can this system work with Lithium batteries as I have to connect directly to the BMS Distributor bar. In this case the wind turbine charges directly into the busbar and the excess of the current is taken away by charge controller, transforming t into heat via resistance.
nesswill avatar image nesswill fordens commented ·
Sorry I missed a link out
Leading Edge
