johnjaymack avatar image
johnjaymack asked
Node Red information on actual inverter inverting power
In Node Red, the VE Bus System has selections for Input Power and Output Power. Is there a selection that show just the power of the Inverter when Inverting? In addition to the VE Bus System module I have looked in the System module, but I have not been able to identify a reading that is just the Inverting power output. Can anyone suggest how to monitor just the Inverting Power?
powerassist
derrick thomas avatar image
derrick thomas answered ·
You might take a look at the dbus. If what you are looking for is there you can use mqtt to incorporate that information into your node red flow.
