Hi Guys, just wanted to check something. I'm looking to put 9x panels on a string of the 450/100 but I'll have an over voltage at low temps.
These will all be East Facing panels, and some will get shading.
Can someone advise please.
@h2009 once you let the blue smoke out of the blue box, it will cease to function.
7 is the maximum # of series panels for the temps those panels will encounter.
Keep the array Voc below both the 450v input limit, and below 8 times the battery float voltage limit.
33 People are following this question.
