I would like to now what happens, when I switch a Multiplus II ESS via Modbus to Charger only / Inverter off and the grid fails? Does the ESS turn the Inverter on or have I to do that via GX by an automation?
Thanks
Edward
Thanks
Edward
ESS will not override the inverter switch setting. (Manual or virtual). If the switch is in "charger only" and grid is lost, the multi will not provide ac power.
92 People are following this question.
