Mike avatar image
Mike asked
Can I use a Centaur directly from Solar?
On our boat we have a nice system.
2.3kw of Solar to a Fronius inverter which is AC coupled to a Quattro. This goes to 1000ah of lithium batteries. And is monitored and controlled by a cerbo gx.
It has AC inputs from shore power and a 6kva generator.
There is a centaur 12/80 from a previous setup. I have just read that the centaur will accept 80-400v DC input. The Solar comes in at about 150v DC The Solar has Tigo optimisers on every panel which kind of do mppt .
My question is, can I connect the centaur to the Solar as a backup system?
It may not be the best most efficient, but I have the equipment already, and as a backup it may be handy to do…
From the manual, it seem that a centaur will accept both AC and DC input voltage
”Universal 90-265V AC input voltage range and also suitable for DC supply (AC-DC and DC-DC operation)
All models will operate without any adjustment needed over a 90 to 265 Volt input voltage range, whether 50 Hz or 60 Hz.
The chargers also accept a 90-400 V DC supply.”
solar
Paul B avatar image
Paul B answered ·
NO that would not work
as the solar output is DC and the centaur would require AC input
Mike avatar image Mike commented ·
The manual states that the centaur can accept DC input supply,
Paul B avatar image
Paul B answered ·
Well Mike I was not aware of that, All I can suggest is give it a go, if it works great.
I have never had the need for a DC supply .
I have now reread the spec sheets and From what they say It should work
