jakudo avatar image
jakudo asked
Updating firmware of Victron devices
I've read many discussions, articles etc regarding firmware updating of Victron devices.
This is what I understood:
  • if it works, don't update it
  • never ever update Multiplus, unless you know how to configure it back since it goes to factory setting after the update (I have 3F system)
  • if needed you can update MPPT and Cerbo GX, it shouldn't delete any settings
Now my questions are:
  • did I understood it correctly?
  • I'd like to install Node-RED on Cerbo GX. If I do that will it preserve the settings if I use the full version of FW? Or will I need to do anything else after the update?
  • there was a new OS v3.00 yesterday. Is it safe to update the FW to the full version of v3.00 with Node-Red if I have v2.92 now?
Thanks a lot.
cerbo gxfirmware updateNode-RED
Hi @jakudo
Yes, don't update unless you have to or want a new feature that comes with a new firmware update.
Updating the Cerbo GX to VenusOS Large (including Node-RED and Signal K) is not a problem. All settings made under 2.92 are retained.
jakudo avatar image jakudo commented ·
Thanks a lot for reply and confirming it. The only reason I need ot update it is the Node-RED
