hanzieo avatar image
hanzieo asked
Easysolar 1600/24 with Pylontech PYLON-UP2500-CAN without a GX device
I have a EasySolar 1600/24 that came in a kit with a PYLONTECH-UP2500-CAN 2 8KWH. There is no GX device and I also can't get one. The supplier tells me it can work UNMANAGED
Can I get some advice on how to set up the battery parameters? Charge profile etc.
Hannes
Pylontech
kevgermany avatar image
kevgermany answered ·
You have to treat it as two separate units.
The MPPT should be configurable via Bluetooth using the Victron connect app.
The Multiplus compact is programmed either through the dip switches, or a mk3 to usb cable using Victron connect or be config software on your pc.
The charge values come from your Pylontech manual
The how to comes from the MPPT and multiplus manuals. All are downloadable.
