gnagflow avatar image
gnagflow asked
Using Nodered without switching off ess an changing to external control
i need nodered for several controling flows, e.g. switching on/off of an big external ventilation for the battery room by the difference of Temperatur between outside/inside temp. Or switching on some heatings when there is too much sun and Soc and so on.
many important things, that can be easy implemented in nodered for a 100kwh battery USV system.
But i don’t want to change from ESS to external control and Programm all the ESS things that are working fine …
thank you
ESSNode-RED
sharpener avatar image
sharpener answered ·
My system is much more modest than yours but NodeRed works fine alongside ESS.
I can check that it is running, for example if you manually change the Inverter Power using Remote Console then you can see NodeRed change it back again to the value it calculates according to battery voltage and time of day.
Otherwise it does not interfere with any ESS settings and the two systems work side-by-side.
