lobongula avatar image
lobongula asked
Orion 12-12 30 Non Isolated - Not powering up and no Bluetooth connection.
I have just purchased to Orion 12-12 30 Non Isolated for my VW T5 campervan.
I have wired it up as specified. However, I am getting no Bluetooth light showing the unit has powered up and no connection showing in the Victron Connect App.
I have run series of continuity tests across :
Battery to just after first (70amp) fuse.
First Fuse to Second (70amp) fuse (4m run of cable).
Second Fuse to Orion input terminal.
All showed continuity.
The power across the vehicle battery posts is 12.53v.
The power across the Orion input terminal and the vehicle chassis is 12.52v.
Neither with, not without the green jumper connection do I have the bluetooth light showing or any connection with the Victron Connect App.
My other Victron components, VE Direct and MPPT controller are all wotking fine.
Any assistance would be appreciated.
orion-tr smart
