lukas80 avatar image
lukas80 asked
ESS Multiplus 2 without GX
Hello all,
I have a Multiplus 2, with battery and a PV system on the AC Out. Now I actually bought the device after some research and now feel kind of stupid because I am not able (or the device can not) to fulfill the simplest and probably most common requirement for me: Solar power into the battery when there is surplus and back instead of drawing power from the grid.
I thought that was more or less done with the activation of the ESS assistant. But after the device does nothing of the sort except for the UPS function, I read up for a while and found out that there is probably basically still a GX device needed for good money. And I wonder why, especially since the device has a current sensor integrated and I therefore just can not believe that an external device must take over the control here.
Could someone tell me succinctly if this high-tech multi-wonder with 1990-flair configuration software really fails on this mini-requirement? And if not, I'd appreciate a little hint as to where this thing is hiding so stubbornly.
Thanks!
Multiplus-IIESS
hominidae avatar image
hominidae answered ·
In short: yes, you do need a GX device.
Your research before the purchase wasn't very detailed, I tend to think, because that fact is given at the first sentence in the ESS Manual: https://www.victronenergy.com/media/pg/Energy_Storage_System/en/ess-introduction---features.html
You can cope with a current sensor instead of a real grid meter.
The ESS-Assistant in the MP2 is not controlling the ESS features, it is enabling the control interface to be used by the GX and (I think) serves as a backup/last resort, should the connection between MP2 and GX fail (in order to not kill your batteries).
You could try and swap your MP2 for a MP2-GX or deploy a Cerbo GX.
I am not familiar with running a normal RPi with VenusOS as a GX substitute...maybe this can be done.
Hope this clarifies some things for you.
Stay safe, stay well.
lukas80 answered ·
Thank you very much. I really wonder how I was stepping over that detail over and over again.
I'll have a look at the Cerbo.
hominidae avatar image hominidae commented ·
obviously, a RPi plus some extra gadgets can work as a substitute, see: https://panbo.com/victrons-venus-os-on-a-raspberry-pi-install-and-configuration/
Edit: latest victron info: https://github.com/victronenergy/venus/wiki/raspberrypi-install-venus-image
...no guarantees, of course....but could safe some dime.
terriblement avatar image
terriblement answered ·
I'm currently trying somme assistants, one make the AC ignored when DC voltage lower than threshold value, AC reconnected when power consumption lower than a threshold.
Not sur if it works as I started the test today
Vincent avatar image Vincent commented ·
Did this work?
