gozzo avatar image
gozzo asked
MPPT 150/70 solar controller connection to 5 panels
Have to install a MPPT 150/70 solar controller on a boat having 24 Volts system voltage.
Originally there were 6 panels with MPP voltage of 31 and 38 V open circuit voltage on the drawing.
MPP current 7,67 A.
Back then I had in mind connecting 3 of them in series resulting in having 2 sets of 3 panels connected in parallel to the controller.
Efficiency would be good and 93 MPP Volts / 114 open circuit Volts within specs.
Unfortunately the boat doesn't allow for more than 5 panels to be installed.
Means I would end up with 1 set of 3 panels in series having 93 MPP Volts and a 2nd set with just 62 MPP Volts connected together in parallel to the controller.
Something tells me this doesn't work.
Connecting all 5 panels in parallel would be another option but with just 31 MPP Volts on a 24 Volt boat's system efficiency would be way down.
Any idea how to proceed here ?
Thanks.
solar
JohnC avatar image
JohnC answered ·
Ho Gozzo. In parallel, it's likely you'd lose low-light performance, ie dawn, dusk & clouds.
I'd be inclined to wire them in pairs, and the orphaned panel to a separate cc, even a cheap pwm.
If you haven't yet bought the 150/70, it's likely you could get away with smaller, and of course a 250/60? would handle a full series string of 5x of those panels. Or even 2x smaller mppt's to fit the separate strings you calculated.
"Something tells me this doesn't work." Yeh, he's often right..
