mppt100-2048 avatar image
mppt100-2048 asked
Current BUG in MPPT 100|20 and some trouble with Android APP
Hello, i have found an bug in the current limit section of the Battery. If I put in an number with comma or point (3.5Amp or 3,5Amp) the app will automaticly jump to the maximum current of 20 Amps! If you confirm that accidently you may blow up an small battery. It should be able to provide 0,1Amp steps in the input field and should not remove my Input and change it to the maximum value by itself.
Also the App is extremly slow and annoying if you switch from one app (BMS) to the Victron App. It do not stay in the Battery configuration Page, also it need to connect again (very slowly) every time you switch between the apps! This is annoying if you want to change the battery amps manually in short time periodes for testing the BMS and ACCU. It looks like there has to come an solution with PC or ESP8266 which is able to change the charge current instantly.
bug report
