Multiplus II 48/3000, Cerbo GX, 10kw Battery
Controlling system via node red, MQTT and home assistant.
If I change the grid setpoint either via MQTT or via the html interface directly on cerbo it changes for a short period 1-2min and then reverts back to zero. See attached picture, blue is grid setpoint, purple is grid power. When i set it to -1000W it exports briefly then goes back to zero.
I have no modbus connections that might be doing this. no export limits set
