I'm new to Victron so I'm actually not sure if my question is more about Victron configuration or MQTT-device driver.
Anyhow, I've set up my 3phase hybrid inverter in VenusOS using https://github.com/freakent/dbus-mqtt-devices
I'm at the point where I have the device showing up on dbus, all the values are being populated and updated. In VRM I am able to display power, voltage and current values for all three phases on Ac In and Ac Out sides. But the system is still showing up as 1 phase and only displays L1 values natively.
This is what I'm seeing on dbus for my inverter:
And when I check under system, I only see L1 values and number of phases is set to 1:
