OxyFly avatar image
OxyFly asked
Solar Panel Upgrade OffGrid
Hello Community,
I'm thinking of upgrading my off-grid system
Right now, i have the following system working 24/7.
  • MultiPlus-II 48/5000/70-48 – v475
  • BlueSolar Charger MPPT 150/60 rev2 – v3.07
  • Cerbo GX - v2.90~24
  • 2 x Pylontech US2000C Plus 48V
  • Q.Cells Q.PEAK DUO XL-G9.3-455w
    1. Vmp – 44.61V
    2. Imp – 10.20A
    3. Voc – 53.22V
    4. Isc – 10.67A
Panels wired in SERIES, then all series strings wired in PARALLEL:
  • Max power output: 1820.09W
  • Max power voltage (Vmp): 89.22V
  • Max power current (Imp): 20.4A
  • Loss: 0%
Option to upgrade my sollar input:
Add 1 new string of PHONO SOLAR 545W BIFACIAL TWINPLUS MONO
  • 2 panels in Series = 1089.99W (Vmp): 82.7V - (Imp): 13.18A
    1. Vmp – 41.35V
    2. Imp – 13.18A
    3. Voc – 49.60V
    4. Isc – 13.86A
All identical panels wired in SERIES, then all series strings wired in PARALLEL:
  • Max power output: 2777.07W
  • Max power voltage (Vmp): 82.7V
  • Max power current (Imp): 33.58A
  • Loss: 4.57%
Add 2 new string of PHONO SOLAR 545W BIFACIAL TWINPLUS MONO
  • 2 X 2 panels = 2179.97W (Vmp): 82.7V - (Imp): 26.36A
    1. Vmp – 41.35V
    2. Imp – 13.18A
    3. Voc – 49.60V
    4. Isc – 13.86A
  • Max power output: 3867.05W
  • Max power current (Imp): 46.76A
  • Loss: 3.33%
What do you guys think is the best solution to maximize the current system.
Cheers for all the opinions.
solar sizing
JohnC avatar image
JohnC answered ·
Hi @OxyFly
Your second option with 2P2S panels will still stay under the mppt's 50A Isc limit, but there's no room for more. That's it.
Not sure how you've worked out your 'Loss' figures. Sure the Vmp's are mismatched, but I think what you'll see in practice is that the lower Vmp of the new panel strings will mostly apply, but drag the overall Vmp down away from the optimum of your existing panels, so they may suffer a little. All good if you can wear that, but you may never notice in practice.
