alan-offgrid-van avatar image
alan-offgrid-van asked
Oversize 100/30 mttp blue solar
Bit of a newbie question.
I have a 100/30 mttp with 3 Victron 140W Solar Panel – Monocrystalline Panel in series hooked into a 200ah lithium 12v battery
Solar specs sre:
140w
Voc 23.6 open circuit voltage
Isc 8.05
Llmp 7.22
Vmpp 19v
So everything is in tolerance…I believe, and all working. I am trying to maximise the set up, so am considering adding an additional panel that would oversize it
System located in Scottish Highlands, so northern hemisphere and low number of optimal days
If I add another panel, by my calculations 4 panels in series - 27% oversized
Watt = 560
Voc = 94.4
Amp = 8.05
Does this look correct? Will this be ok?
Does anyone have any other suggestions for maximising the above, like wiring panels in parallel?
Many thanks
solar
wkirby avatar image
wkirby answered ·
Having 560W of PV feeding this controller will not be a problem. The MPPT will take as much as it possibly can from the array. Over sizing the array is a good idea especially in areas where fine weather is rare.
The Voc figure is given for a panel temperature of 25°C. At lower temperatures, which I believe are likely in Scotland, then this Voc figure will be higher and may exceed the 100V limit of your controller. The MPPT controller is likely to be damaged if your PV Voltage exceeds 100V.
It would be better to wire the four panels two in series strings which are in parallel. This would bring your Voc down to a safe level for your controller, but it would still be high enough to work well in a 12V system.
alan-offgrid-van avatar image alan-offgrid-van commented ·
Thanks fir your advice. Much appreciated.
