alaskannoob avatar image
alaskannoob asked
How to update MPPT RS 450/200 Firmware
How do I update the firmware of the MPPT RS 450/200 without an internet connection? It is showing Firmware v1.04 and I am connected to it via the Cerbo GX on my LAN. The MPPT is connected to the Cerbo GX via VE.CAN bus. The MPPT does not show up in Victron Connect. Many thanks for any help.
MPPT SmartSolar
wkirby avatar image
wkirby answered ·
Is your site on VRM?
If so, you can select Device List on the left menu then below the list of devices is a Firmware Update button. Press that button and your installation will be scanned for device firmware updates.
1676126112807.pngAny devices that have updates available will show up with a blue Update Device button.
I'm not sure why you can't connect using VictronConnect. Did you mention that you are using a Windows version of VictronConnect? In that case you'd need to connect to the device using a VE.Direct cable to your computer. Otherwise you could use VictronConnect on a telephone or tablet device.
alaskannoob avatar image alaskannoob commented ·
I am not on VRM and do not have internet on my solar devices.
Yes, I have a Windows machine. Bluetooth connection from Windows machine isn't supported.
I went to the Victron Pro Firmware page and read the .doc and it stated as you have done, I need to get a VE.Direct to USB interface cable. I will look for one, thank you!
alaskannoob avatar image alaskannoob alaskannoob commented ·
I bought an Android device and connected via Bluetooth to update the firmware and it worked well. Would be nice to be able to use just one machine, my laptop, to update everything but will keep the android device for now.
