we are responsible for several pv plants with a combination of some SmartSolar MPPTs, Quattro inverters and either a Color Control GX display or a Cerbo GX unit.
The values of the plant are read out by communicating with CCGX/Cerbo via Modbus TCP using the registers from the CCGX-Modbus-TCP-register-list-2.90.
However, we are trying to get the total generated energy by reading out the user yield (address 790): Energy generated by the solarcharger.
This register is defined as uint16 and has an overflow each 6553.5 kWh.
- Is there any way to get a total counter of the pv generated energy as uint32 or similar?
- Also it seems that there is no way to read out the 'lifetime total energy' mentioned in the manual of the SmartSolar MPPT.
I would be grateful if someone could help me solving this issue.
Regards, Leo
