Does anyone know if hub4control is open source? If so, any idea where?
I can see it’s an qt app from a quick look. I have it doing some crazy stuff, but rather than debug it the hard way it would be quicker to use the code if available…
Pretty sure that's closed source. (IIRC "ESS" is coordinated by hub4control)
Whilst any individual use case may be trivial, I assume hub4control is a bit of a monster because of all the of use cases it has to handle.
I'd assume it lives in private repos.
52 People are following this question.
