qits avatar image
qits asked
Batteries in parallel
I have a 10kva multiplus 2 with 7 bluenova batteries in parallel.The last 2 batteries which i bought does'nt seem to charge at the same rate as the other 5.EG The 5 will have SOC of 78,79.80,78,77 but the other 2 will be 30,32.I have tried everthing As I even change my inverter .So please help
48v battery
nickdb avatar image
nickdb answered ·
That is best taken up with Bluenova. They generally tell you to check with them before getting creative with batteries. All batteries won't just magically work with other ones - differences in firmware etc.
You can also run through the setup guide:
https://www.victronenergy.com/live/battery_compatibility:bluenova
