ako avatar image
ako asked
Smart Solar MPPT Tr
Thanks to all the advice and explanations of the difference between several models of MPPT 150-70 , i am going to order the 150-70 Smart Solar Tr . I have just 3 more points im unsure about .
Can a Smart Solar MPPT temperature and voltage be controlled from the Cerbo using DVCC
Can the Smart Solar be connected to a Cerbo via a VE Direct to USB cable or does it have to be a VE Direct to VE Direct
How are the settings transferred to the MPPT if its set up Using Victron Connect on a Windows Laptop . On VRM i did this on a Multiplus with VE Configure and uploaded a file when prompted .
MPPT SmartSolar
klim8skeptic avatar image
klim8skeptic answered ·
Have a read of the DVCC manual.
Either is fine, though the VE Direct to VE Direct cables are likely less costly.
Grab some popcorn.
