luc-bosmans avatar image
luc-bosmans asked
Modbus address 258 is not registered
I want to connect my Raspberry/Node-red to a Multiplus II GX to read some values.
Battery power does not report a value when I use the Modbus protocol.
This is the error that the GX reports:
ERROR "Error processing function code 3, unit id 225, start address 258, quantity 1, src 192.168.0.4: Modbus address 258 is not registered
- Other values can be read, ie battery voltage on address 259.
- Pylontech battery
- Multiplus II GX version 2.92
I use CCGX-Modbus-TCP-register-list Rev 44 as reference.
Am I doing something wrong?
Thnx,
Luc Bosmans.
Modbus TCP
wkirby avatar image
wkirby answered ·
Register 258 is not on the current list. Rev.43 is the one I downloaded a few seconds ago, not sure about rev. 44
You can get battery power from register 842 (slave 100).
6 comments
Alexandre PY BLOUCH avatar image Alexandre PY BLOUCH commented ·
Dear @WKirby do you know the Modbus adresse from Pylontech Temperature ??? for monitoring it in my Home Assistant OS...
-1 Like -1 ·
wkirby avatar image wkirby ♦♦ Alexandre PY BLOUCH commented ·
# - name: "Battery Temperature"
# scan_interval: 5
# unit_of_measurement: "°C"
# slave: 225
# address: 262
# scale: 0.1
# precision: 1
-1 Like -1 ·
Alexandre PY BLOUCH avatar image Alexandre PY BLOUCH wkirby ♦♦ commented ·
Ho ! Ho !
THANK YOU VERY MUCH @WKirby It's Work fine !!!!!
I put this :
      - name: "Pylontech temperature"
        slave: 225 #HUB
        address: 262
        data_type: int16
        scale: 0.1
        precision: 1
Alexandre PY BLOUCH avatar image Alexandre PY BLOUCH Alexandre PY BLOUCH commented ·
@WKirby could you explain me WHERE you found this information ;) ?!!!
-1 Like -1 ·
@Alexandre PY BLOUCH This information is available in the Modbus TCP Register list. The Excel file is available from the Downloads section:
https://www.victronenergy.com/support-and-downloads/technical-information
-1 Like -1 ·
Many Tanks for week-end working @WKirby
luc-bosmans answered ·
Indeed, version 44 seems to be removed from the website.
The actual version is 43.
FYI, I copied the version details of 44 below.
Modbus address 100/842 works fine.
Thanks @WKirby ,
Luc.
Rev 44 Document state 17 for battery state (Contactor check)
Add registers for pump-related controls
Add register for VE.Bus BMS (v2) pre-alarm
Add 32-bit registers for Multi-RS and SolarCharger total yield
Add register for VE.Bus charge state (similar to VE.Bus state, but provides additional info, and works better with managed batteries)
